Technically, ALL VFDs can operate from single phase power. A VFD just converts AC to DC, then recreates something that motors react to as if it is AC again ("pseudo AC").
Where you get into trouble with this is in the rectification process. With a single phase input, only 4 of the 6 diodes on the diode bridge rectifier are going to carry ALL of the current, with means that the current through the diodes increases by the square root of 3, 1.732x. But in ADDITION to that problem, your DC bus capacitors have to work a LOT harder to smooth out the "ripple" in the DC bus from the rectifier. In a 3 phase input, the DC bus never gets to a zero voltage state, so the capacitors don't work all that hard and run cool. But when you have a single phase input, the ripple will drop all the way to zero V 120 times per second, so the caps must work harder and they will get hotter. That is really what the de-rate factor is all about, and depending on the VFD design, that de-rate factor can be anywhere from 50% to 65% (meaning the maximum motor size is 35% of the VFD rating if run from single phase), typically depending on whether or not the VFD has a DC bus choke or not. Most VFDs built to US or EU standards will have DC bus chokes, most Asian drives will not and require more de-rating (or a de-rating of the temperature to 25C/77F operation).
But also for this reason, SOME of the VFD mfrs will put in a "Phase Loss" detection and protection circuit that simply looks for the loss of any phase and shuts the drive down so that the DC bus caps are not damaged. Then SOME of those mfrs, for some reason, do NOT allow you to disable that Phase Loss Trip function. Those are the only VFDs that cannot operate from single phase, but only because the mfr is not ALLOWING you to do that. If you are not sure, look at the instruction manual and if they HAVE a Phase Loss trip function, look then to see what it means* and / or if it can be defeated in programming. This inability to defeat it however means that people like you, meaning people with only single phase sources and 3 phase machines, are lost to them as a market potential. For that reason, this issue has been going away as more and more drive mfrs catch on.
*One WAY of detecting whether or not you have a phase loss is to monitor the DC bus ripple, since that's really the only issue. So for example all A-B drives do this, meaning they don't actually look to see if there is voltage on each line terminal, they only loom at the EFFECT of a phase loss. So if the motor is lightly loaded, OR the VFD is over sized, the VFD does not have excess DC bus ripple and hums right along. So on A-B and ABB drives there is no way to defeat the Phase Loss trip function, but by reading the description of HOW it detects a phase loss (excess DC bus ripple), you can understand that by de-rating the drive, it will be fine.
