Hi everybody,
I have a newly acquired Emco Super 11 with an AEG motor running on household (single phase) 120V. The motor is actually a 115V 3-Phase unit using a capacitor to run off the single phase input. I'm planning to convert to VFD eventually so I'm wondering -- has anybody has done that?
It seems a VFD with 120V/1Phase-in to 120V/3-Phase-out is a bit of an oddball. I can't find one specifically rated for 110-120V 3-phase output.
Also, I'm a bit confused on this point since the catalog entries only specify input voltage. e.g. CFW300A06P0S1NB20 | Weg | AC Drives -- why is that?
A couple other questions:
The original gang switch flips the motor from Delta-connection (slow speed) to Y configuration (Dahlander for high-speed). Which configuration do you use with a VFD? -- Delta?.
Could you run that on 220V 3-Phase output given the Delta-configuration has the windings in series and the VFD is current limited?
Thanks ahead of time.
-Dave
-Dave
