M. Moore
Titanium
- Jun 8, 2007
- Vancouver Island, B.C. Canada
I posted about the torque issue on the CNC forum so there is more to the story however this is the latest issue and I am hoping the amazing electric guys here can help out.
The machine is intermittently slowing down in a medium cut and the first time it happened I had my hand on the feed knob so I slowed the feed and it recovered and completed the cut. So this happened a few times. I checked and tightened all wiring and had to relocate the VFD so I could open and check the wiring. (it was on the back against the wall) The wires seemed fine except one control wire jumped out of its spot when I first tried to straighten out the wires. It was either doubled with the red or on its own next door. I could not read the number that was poorly written on masking tape. The terminal for the red wire which was labeled 17 was a bit loose so I put them both in 17.
Then tested the motor and it started to pulse at 2200 rpm, revving or pulsing up and down maybe 40 to 80 rpm as seen on the VFD readout. I then tried the white wire in spot 16 and there was no change in the result. Hopefully I did not do any major damage with my fumbling as I was not expecting one of the wires to jump out so easily.
Earlier in the day the motor amp draw tested a little low on one leg and the same on the other two and the motor sounded fine at 2200 rpm, no pulsing. Also the voltage at the motor was perfect across all three legs. The control is able to change the speed fine and at 3500 rpm the pulse is less noticeable maybe 15-30 rpm.
So any ideas or more info and testing needed? Is the VFD on its last legs?
