VFD DC injection and dynamic braking transistors/resistors discussion
Likes Likes:  0
Results 1 to 9 of 9
    Mar 2005
    Northwest Indiana
    4,216
    845
    847
    Default VFD DC injection and dynamic braking transistors/resistors discussion
    So having recently picked up the 25 H.P. Baldor VFD from my other thread, I've been thoroughly reading the manual and discovered that a series 15H, "E0" drive has no dynamic braking hardware. It will do DC injection braking though. My thinking has been in the direction of just repairing and using the lathe's mechanical brake and not worrying about that.
    However, reading up on the subject has gotten me interested in how exactly it works. There are two terminals at the terminal block labeled 'B+' and 'B-' that I assumed were connected to the DC bus and that seems to be the case, as the voltage reported by the drive as 'DC Bus Voltage' and the voltage at those terminals is the same. There are also two terminals that are related to the braking labeled as 'D+' and 'D-' that I'm not sure about. All four are to be connected to the external braking transistor and resistor, along with their grounds of course.
    How hard would it be to create my own external unit just to do it for the experience? I'm fairly well versed in basic electronics and have created other circuits, repaired plenty of surface mount and through hole electronics, etc. Seems like it shouldn't be too complicated, to simplify it, just have to figure out how to drive the transistor so it activates the output to the resistor once the voltage on the DC bus hits 380V then shut it off after it drops down to 360ish.
    Dec 2003
    Washington
    4,712
    2223
    4057
    Mar 2005
    Northwest Indiana
    4,216
    845
    847
    I could, but I wouldn't learn a whole lot... sort of the purpose of the exercise.
    Jun 2001
    St Louis
    18,020
    1886
    3037
    Quote Originally Posted by eKretz View Post
    You DO have the dynamic braking hardware.
    What you do NOT have is something to deal with the energy that the dynamic braking dumps back in he DC bus. I suppose that could be a difference without a distinction, but it actually is an issue. The resistor is not needed to DO the braking.... it is needed to avoid the braking causing a shutdown on fast stops or high inertia loads.
    The Bonitron, or their competitors, will cost you several times the amount that rolling your own can. But it is a "guaranteed solution".... I have used them, and they work very well.
    Mar 2005
    Northwest Indiana
    4,216
    845
    847
    No, I dont. The E0 drives have no internal braking transistor, it's an external-only on the E0, so you have to add it on. For dynamic braking you need the transistor to turn on only when the DC bus voltage gets above a certain level, then the energy gets sent to the resistor for dissipation. Afterward, the connection needs to be broken once the bus voltage drops back within normal limits. If I connect just a resistor it will be active all the time on this particular drive because there's nothing switching the connection.
    Dec 2003
    Washington
    4,712
    2223
    4057
    The transistor acts as an analog switch by employing a PWM waveform. As such simply turning it on when the bus is high and then turning it off when the bus is low with a duty cycle measured in msec wont likely give good results and may screw up the inverter current regulator performance. DB resistor circuits generally have a switching frequency of 2 or more kHz with a variable pulse width duty cycle to keep DC bus level under control.
    Mar 2005
    Northwest Indiana
    4,216
    845
    847
    Ah, so it's a little more involved than I was thinking. Thanks for the clarification.
    Jun 2001
    St Louis
    18,020
    1886
    3037
    It IS possible to just switch a resistor in and out as needed, if you set the "off" and "on" points correctly. The PWM is slicker, of course.
    There is also the point that the resistor may need to be monitored, or the duty cycle set, so that it is not over-powered and damaged/"burnt up".
    Yes you do have it. The actual braking is done by the same parts that produce the motor currents to begin with.
    What you lack is the resistor and switch assembly to prevent the dynamic braking from "pumping up" the DC bus too high. For lower rates of braking, the inherent power use of the VFD can handle the braking energy without letting the DC bus get too high, and the braking needs no "dump resistor".
    That's the point... dynamic braking is just a change in the way the IGBTs are switched in time. It pulls the energy out of the motor, and puts it on the DC bus as "returned charge" on the capacitors (that raises voltage).
    In some systems that have multiple motors and VFDs, there is NO resistor, the braking energy from some motors/loads is used by other motors running different parts of the machine. And in still other systems, it is put back on the AC supply line, by a "bidirectional" inverter.
    Mar 2005
    Northwest Indiana
    4,216
    845
    847
    Yes I get all that. I am still missing hardware that is necessary to really use dynamic braking in my application. The resistor and switch are hardware... I do appreciate the elaboration though.
