Sorry to clog up this VFD forum with yet more of same questions as many others, but I've searched past posts for answers, THINK I'm on the right track, but am still a little unsure before I pull the trigger and buy a VFD.
The basics:
Lathe, De Vallière H 130C,made in France, circa 1950's.
Motor: 3-phase 2-speed 850/1700 rpm 1.6hp/3hp. I would be operating on 240 VAC single phase.
Motor nameplate data (most in French:
Type D81.60
Current TR 1
Frequency 60
cos. 0.70
Volts 220 Amps 6.8/9.5
RPM 850/1700
Service 141372
What I've concluded so far (if you think differently, please answer):
- Buy quality from a reputable dealer and don't try to save by buying cheap unknown Chinese brands from Amazon
- Chose at least a 3 HP or larger VFD to run a 3 HP motor
- For use with a two-speed motor permanently lock the speed switch on the lathe at the high position and then use the VFD to set the lower speeds.
- Slight worries about upstream spikes or harmonics from a VFD affecting our household electronics/appliances, or those of neighbors on our grid. Have read that adding a load reactor can supposedly minimize, but not eliminate this. Don't know how true this is.
Thanks for your help, and any other views or suggestions.
Richard
The basics:
Type D81.60
Current TR 1
Frequency 60
cos. 0.70
RPM 850/1700
Service 141372
Richard
