WickedTwins
- Sep 20, 2021
Hello Everyone, I've read your information for a while now but this is my first post. I'm asking for some of your experience and insight. I recently purchased a used Bridgeport Mill with a 2HP 230V 3 phase motor. It's specs are:
US Electrical Motor
230V
Max Load Amp at 230V: 5.8 AMPS
HP: 2
Phase: 3
Cycles: 50/60
Duty Cycle: 2 HP Continuous, 3 HP 30 Minute Intermittent
Since this is for my house, I have to convert from 1 phase to 3 phase for the motor. I've read through several posts and it appears the Hitachi VFDs are a good choice. I think the correct Hitachi VFD for my situation would be the Hitachi WJ200-015SF VFD. This is were I would like your insights. First, would you agree with this size VFD? Second, if this VFD is a good choice, should I consider sizing up to the Hitachi WJ200-022SF. The 022SF is the next choice up and has a higher HP / AMP rating. Lastly, would anyone recommend the FUJI, Schneider, or Dayton brand VFD's. Each has a comparable VFD as the Hitachi 015SF. I'm not a commercial machinist. I'm trying to learn and this is something I always wanted to do. So, the mill won't be pushed to its limits by any means.
Thank you for any info / experience you can offer. I would appreciate it.
US Electrical Motor
230V
HP: 2
Phase: 3
Cycles: 50/60
