Hi guys,
Just a quick question which is probably going to be stupid but the output voltage in the specs on these VFDs whether they be Hitachi or china-noname, is it the voltage per phase i.e. what you'd measure between each motor terminal and neutral or the delta wired motor voltage (if I've said that right..)
Here in NZ our 3 phase voltage is considered to be 400V 50hz, so I'd expect to see a VFD that has a 3 phase output to be 400V, am I reading it wrong or have I got the wrong model?
Thanks in advance
Josh
Thanks in advance
Josh
