Sorry for the newb question. I'm looking to get a lathe up and running.
I've done a fair amount of research,but want to make sure its done right the first try.
I know that the VFD needs to be oversized and was planning on using one 15hp rated.
What I'm not sure on is if I should wire the VFD directly to the motor's high speed input and use it for all controls.
Or to wire the vfd in place of the contactor, and keep the existing lathe switch. I have read both ways being used, and that you have to be careful to never switch speeds with the motor turning.
Any suggestions?
Any suggestions?
