challenger
Stainless
- Mar 6, 2003
- Hampstead, NC-S.E. Coast
I have a 10" Sheldon lathe. It came with a 3/4hp motor which has disappeared since I changed to a single glue phase years ago. I now have a VFD rated for 3hp. It is an automation direct g2 series. I initially had a 3/4 3-ph motor on it but I've been able to stall the motor very easily. This is something I have not experienced with the 1hp single phase motor. I have the pulley set up using smallest motor and largest spindle which should give the most power from the motor. I can see the current go past the nameplate spec of 3.5 amps so the motor is definitely getting over powered by the turning.
I had another 2hp motor lined up for purchase but the guy backed out so I am going to put a 3hp on the lathe. It will barely fit under the lathe in the cabinet but it will work. I've had to remove the motor mount and drill new holes for the foot. I am wondering if I should set the maximum amps to a lower number than the nameplate as protection from putting such a large motor on it?
