VFD Speed modulator to counteract chatter in a lathe
Likes Likes:  0
Results 1 to 6 of 6
    Sep 2019
    FINLAND
    10
    Talking VFD Speed modulator to counteract chatter in a lathe
    I have an import lathe that is not that rigid. Therefore I often have issues with chatter.
    I have come across several time on a solution that might medicate some of this chatter problem.
    Since chatter is actually a resonance condition and it takes some time to develop. I mean, the chatter does not start right away, it may take a second or two to develop into the disturbing form.
    If the spindle speed is varied constantly, this does not allow enough time for the chatter to develop. I have done this manually, since I have a VFD, and it looks like it could do something for the problem.
    For this reason I have designed a device that involves a microcontroller (Atmel Atmega32) and some PWM filtering. I am at the moment on making a housing for that thing and then go into practical testing with the lathe.
    I have made a video series of this thing in YouTube at Finno Ugric Machining
    Aug 2004
    2,782
    29
    671
    Higher end VFDs will do this for you automatically by the way.
    Sep 2019
    FINLAND
    10
    Higher end, yes, but the ones I can afford lack this kind of service. Either I have to keep on doing that manually or then make a thing that can do the knob twisting for me.
    And then there is one more thing in play here. My profession is not a machinist. I am a darn IT-Consultant who does not do machining for living - it is a hobby for me. Therefore I am willing to make the feature myself.
    Aug 2004
    2,782
    29
    671
    Quote Originally Posted by FinnoUgric View Post
    Servo controllers do this too. It's called a "Load Observer" functionality, but typically needs an encoder feedback (inherent in most servo drives).
    Mar 2006
    Auburn CA
    435
    5
    39
    Because I an old guy I would have taken an analog approach. A function generator chip a handful of components and done. No programming. A couple of pots to adjust amplitude and frequency and maybe a switch to set waveform type.
    Apr 2010
    Surrey, England
    373
    1165
    75
    Not exactly what you're doing, but I set up near-constant-surface-speed by using a long-travel slider potentiometer coupled to the lathe cross-slide to control the VFD frequency, wiper goes tot he analogue input (0-10v), the ends of the slider pot go to the wipers of max/min setting pots (with resistors to bias them to 0 to half, half to full) - it helps a lot getting a decent surface finish on facing cuts and adjusts to part diameter on successive cuts. Doesn't give infinite speed at the centre though!
    Could you couple an AC waveform of a volt or so peak-peak into the analogue input through a capacitor? Similar to Bill's suggestion?
    Dave H. (the other one)
