I recently acquired a 3HP Lagun FTV-2 Mill with variable speed pulleys for garage hobby use. I have it hooked up to a Teco L510 VFD. The variable speed pulleys (sounds like the one on the motor) have a problem. A loud knock that gets much worse as the speed is reduced to anything below top speed.
I haven't figured out how remove the motor yet, as I have a bad back, and probably couldn't do it with a good back, so I'm not sure what the fix entails yet.
But I'd just as soon use the VFD for speed control, regardless of what's wrong with the mill. Replace the variable pulleys with standard pulleys if that's feasible.
Which brings me to the reason for this post (finally, you're probably thinking). I read that non-inverter duty motors won't hold up to varying the frequency. *But*, I read here and see on youtube many people using VFDs with older mills and lathes with apparently no problems.
What do ya'll think?
