VFD Wiring to existing Control panel Help - Page 2
Likes Likes:  0
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Mar 2009
    Eureka, CA
    3,622
    698
    1196
    On a Clausing I used to run that was a clutched lathe, the apron lever not only engaged the spindle, but when moved hard down, it applied a disc brake. I wonder if your apron lever and it strange movements will actuate the brake as well. It would make ergonomic sense to do so..in my thinking.
    Stuart
  2. #22
    Mar 2019
    South Carolina
    30
    I want to say thanks to everyone that took out there time and helped me out. Also a special thanks to Stuart. The game plan worked out this morning. Lathe is running as planned with the push buttons using the exciting contactors and using another 220 source hooked to the Transformer. I was worried about the VFD I bought. I did my research and by god the first time everything worked. Yeaaaaaa!!!
    A Leaphart
  3. #23
    Mar 2009
    Eureka, CA
    3,622
    698
    1196
    Good show...sometimes things work out as planned.
    Stuart
