Video Review Request - Running a 3 Phase Machine with Single Phase Power Using a VFD
Results 1 to 13 of 13
    Oct 2015
    Virginia
    25
    Lightbulb Video Review Request - Running a 3 Phase Machine with Single Phase Power Using a VFD
    Hi everyone. I'm working on a series about VFDs and phase converters and I was wondering if you could review the following video. I get lots of inquiries about how to run 3 phase equipment off of signal phase power and I'm trying to make sure I'm covering all the details. In this video I go through the basics of installing a VFD to a 3 phase motor, next week I'll go over how my phase converter works, then I've made a miniature model of a phase converter where I can really go into the details of how it creates 3 phase power, how it gets started rotating, and some basics on phase balancing. What have I missed or what else should I include? Also you should at least check out this 1800s shaper running at the end of the video. She's a real beauty.
    YouTube
    Thanks in advance. I enjoy reading the post hear near daily but as an automation guy whose more of an amateur machinist I try not to chime in.
    Oct 2015
    Virginia
    25
    I've posted the second part which is about rotary phase converters. I've made a miniature rotary phase converter that I'll use to go through the details of how it works.
    How to Make 3 Phase Power from Single Phase Power Using a Rotary Phase Converter including 480VAC
    Dec 2010
    Mifflintown, PA 17059
    1,747
    20
    187
    You shaper looks to be running backwards because the belt is slipping on the back stroke, It's not the world's smallest shaper, there are bench top size available. You dad is not running a shaper! It's a Planer, Difference is shapper the cutting to moves, planer the work attached to the table moves. The shaper to take more material off the table with work attached is moved and Planer the cutting tool is moved. They are opposite in operation. The machine you dad is operating is known as an open-side planer. A while ago shapers were considered boat anchors and were sold at auction for scrap. But now they a being used again. Lots of things that shaper can do your mill can't like cut an internal keyway unless you have the shaper attachment. But it only has a short stroke.
  4. Likes TimWilborne liked this post
    Oct 2015
    Virginia
    25
    Haha yes I figured that out later. It took me some studying to understand how the vary the stroke on it. It's a fascinating machine. Thanks for watching!
    Oct 2015
    Virginia
    25
    Interesting the difference between a shaper and a planer. Maybe they did call it a planer, it's been many years ago and I was about 12.
    At full stroke the connecting rod was rubbing the back of the casting which was why it was slowing down. Still it was backwards, mainly the feed numbers were running the wrong way. Once we got it lubed up really good it ran smooth.
    I've still got to find an antique box to but the drive in for the guy but it was one of my more interesting recent projects.
    Mar 2008
    Marulan N.S.W. Australia
    153
    76
    38
    Hi Tim,
    The Shaper's motor rotation should be to give a quick return after the cutting stroke.
    Jim
    Oct 2015
    Virginia
    25
    Quote Originally Posted by Jim Kennedy View Post
    Hi Tim,
    Jim
    Looking at 18 minutes and 7 seconds, I can't understand how the stroke is faster on the return. I can physically see it, I just can't follow why
    18 minutes 7 seconds of the video
  9. #8
    May 2019
    226
    44
    66
    Quote Originally Posted by TimWilborne View Post
    The speed of rotation is constant and the distant moved is constant but the time spent on return is less therefor the velocity must be higher.
  10. #9
    Oct 2015
    Virginia
    25
    Quote Originally Posted by Hardplates View Post
    Ah, a picture is worth a 1000 words. Thanks for the lesson!
  11. #10
    Oct 2004
    Iowa
    3,130
    61
    371
    If you do much work on engines, you'll find that SOME, especially high-performance 'experiments', you'll find that they're designed with the centerline of the cylinder bore offset from the crankshaft. They have several reasons for doing this, but the geometric result is that the offset changes trigonometry such that piston speed in ONE direction, is naturally higher than the other. While the mechanical drive of your shaper is different, some use offset crankpin, regardless the result is the same... the velocity is higher, and force lower, on the return stroke than on the working stroke.
    If you're a mathematician/physicist/engineer, you'll see the relationship of geometry, but from a METALWORKING standpoing, why would this matter?
    Simple... the velocity of the cutter THROUGH the workpiece is important. Having a faster return speed isn't substantially important, but having the cutter make a consistent pass, with consistent force, and consistent chips, is everything.
  12. #11
    Oct 2015
    Virginia
    25
    It is amazing the engineering that went into these machines. When you first glance at it, it looks crude but every little piece has been carefully designed.
    I put out a video today laying out the equipment I'm going to use to go through how VFDs and Rotary Phase Converters work. Rotary Phase Converter and VFD Workbench Preview - What Topics Should We Cover?
  13. #12
    Jan 2012
    Oregon
    125
    8
    44
    I really enjoyed your video on the shaper. They are fascinating machines, I've heard it said that you can make anything using them in the shop except money!
    Dan
  14. Likes TimWilborne liked this post
  15. #13
    Oct 2015
    Virginia
    25
    Quote Originally Posted by DanLinsch View Post
    Dan
    Haha, that's a good saying! Thanks for watching
