Vintage Motor Bearing Box Lubrication Packing Material?
Likes Likes:  0
Results 1 to 5 of 5
    Dec 2008
    North Carolina
    685
    200
    158
    Default Vintage Motor Bearing Box Lubrication Packing Material?
    I’m not sure this is the appropriate forum for this question. If not please direct me to proper one.
    I am refurbing my lathe from 1943. One of the tasks is to clean out the neglected 3/4 hp, 220/440 VAC motor.
    I took the motor end bells off and, in preparation for scrubbing and cleaning, pulled opened the ports on the sleeve bearing lubrication boxes. Inside these boxes I found what appear to be skeins of wool yarn to hold the oil.
    What should I use to replace this bearing box packing material? Should I go to the local fabric shop or hobby shop and by some wool yarn to make new skeins for the bearing boxes? Perhaps stuff them with loose felt, wool or cotton?
    Thank you for any replies,
    Vladymere
    Attached Thumbnails Attached Thumbnails 20200209_183546.jpg   dsc02320.jpg   dsc02321.jpg   dsc02322.jpg   dsc02323.jpg
    Mar 2009
    5,586
    103
    1079
    Amazing that stuff has lasted.
    It's pretty simple to put everything back as it was. I would think about boring a hole in each end bell to fit a modern bearing.
    Aug 2012
    California, Central Coast
    4,244
    2253
    1678
    Can you just clean it of old oil and reuse it? Or does it fall apart when do anything to it.
    Some info here:
    Motor Lubrication: Wick bearing lubrication
    From the link:
    "Motors with this lubrication system have a cotton or woolen yarn, saturated with oil at the factory."
    Jul 2007
    Missoula Mt
    269
    6
    99
    Wool felt,or wool yarn...no cotton, oil wicks well thu wool will not wick with cotton...Phil
    Dec 2008
    North Carolina
    685
    200
    158
    Fellows,
    I thank you for your responses.
    It seems to be OK really. Not broken or damaged, sound and solid.
    I think I will rinse the skeins in mineral spirits and dry them, apply some oil and stuff them back in the end bells oil reservoir boxes.
    Vlad
