Well, The test has been made, and an answer given on one VFD that just happens to be on my test bench.
YES! Well ....sort of.
Here is the story. Based on this original post question, I picked up a 440 V VFD at a comfortable price. The unit requires 3ph input and mentions consulting the factory if single phase input operation is to be considered
Since I don't have 440 V 3ph service in my shop, some alternate sources of supply were evaluated.
First, Direct 240V single phase to L1 ,L2 or any combination with L3 got the display to light up, But a reset, display change, or data change was not to be.
Second go: the output of the home built 240 V RPC was clipped into L1,L2, L3. Bingo! The display lit up, and data could be modified. (LOTS of options) But, Though at times it appeared that the unit was on the verge of useful operation, It only took a finger waving at the frequency increase key and the under voltage warning would take it's place on the display. Clearing the fault would get back to the "near working" state, but when the low voltage detection time expired (set to 10 sec.) the fault warning returned. The undervoltage trip had been disabled previously. I thought there might be a chance that the unit would go operational in spite of the fault message, but that was not to be. The fault message must have been cleared 500 times in hope ;-)
Some feelers were put out to try and snag a step up transformer, and I even made a trip to the local shop where I new there was 440 V service. No luck on the transformer locally, and a hand written sign on the shop door told me that this was the afternoon when "something came up. No Go.
Well a brainstorm will raise a lot of dust. With a sleepless night "figuring the angles" I thought to put a ganged Variac that is in the shop inventory to the task. Perhaps a little voltage boost would be enough. Variacs allow about 25% boost over line voltage.
And.... Yes! With two legs of the RPC runing through the Variac and boosted to 290 Volts and the third leg at about 270 to either of the other two, the drive smiled its 00 frequency and made a soothing fan sound suggesting all was well.
I clipped in the little Italian .27 kw 220/380 volt motor that is kept on the window sill just because it looks so cute. and Viola! As the Freq. increased, the motor shaft began turning! (The motor profile in the drive had been setup just for this little guy)
After what seemed like way too long acceleration, (A review of the parameters discovered the default acceleration was set at 60 seconds) the little motor was spinning it's heart out on the bench and I could see that the drive was not going to let up until some real speed was had. I pressed the stop button at about 80 hertz
I played around this way for about a half hour, and then what do you suppose? The low input voltage warning showed up (well, actually, I moved the dial on the Variac, and that dropped the in line voltage just that much. It must have all been right on the ragged edge of operation. It was time to call it a day. so I just packed all the clip leads away for a fresh go another time.
In recap
Some 440 V 3ph VFDs will function at about 290V 3ph input.
Not in any useful way however ;-)
Perhaps all would be fine at 330 V.
A bank of 3 buck-or-boost transformers might be a next step. It would be fun to find out what minimum single phase voltage is needed to power up the DC bus.
A day in the shop!
CalG
