John.t.little1
- Oct 10, 2014
- St. Augustine, FL
So after the 10hp used rpc I picked up went out I figured id make me a new rpc. I have a lathe and older cnc mill I plan to use the rpc for. Here is pictures of the data plates off each motor. What size motor should I get and caps if I plan to use both at the same time occasionally? Thanks for the help-John
Lathe
Mill
Lathe
Mill
