The voltage to ground readings I get with my RFD are roughly 120, 120 and 230, the latter being the generated leg. Can someone explain the reason behind it?
"to GROUND", not leg-to-leg is your klew.
Search and read on "corner grounded delta", "high-leg delta", whether ground-referred AT ALL ("floating") and the differences in general between Delta and Wye distribution / supply.
Pay attention. Shock hazard is not a trivial item, here.
After some reading on "high leg delta" as suggested by thermite I'm beginning to understand the increased voltage to ground on one leg. Ronk mentions in their literature that the generated leg is labeled as the "A" phase. My reading suggests however that it should be identified as the "B" phase and marked with orange tape. Is this a matter of Ronk not following the code or is there some latitude in the marking system?
RFD? is this a new PHase we are going through?
Rural Free Delivery. It was how you got 3-Phase in up-holler West By God Virginia outta mail-order catalogs.
Arizona must be having some tough times..
Naw, I knew what he meant. It was Roto-Faze Doer......wasn't it?
Notice
