Domodude17
- Aug 14, 2017
I have a Teco L510 VFD wired up to my lathe, 3/4hp 3 phase motor. I've got it set to operate between 0hz and 100hz max. I have a 5k ohm potentiometer from Automation direct I wired in to control the speed. At the full left position, the motor is at 0hz. Turning the pot, the motor reaches the max frequency through maybe 70% of the travel. so once the motor is at max frequency, the pot can continue to rotate further without anything happening. I'd like to adjust it so full left is 0hz, and full right is 100hz.
Does anyone know if there's a fix to this? Maybe a setting in the VFD somewhere? I have looked through the manual but didn't see anything that immediately jumped out at me.
Thanks in advance!
Thanks in advance!
