Wireless Switches: Do SPDT and SPST wireless switches exist?
Likes Likes:  0
Results 1 to 8 of 8
    Sep 2002
    Salinas, CA USA
    4,125
    259
    226
    Default Wireless Switches: Do SPDT and SPST wireless switches exist?
    Note, the title is wrong but I can't edit it. Should be do SPDT and DPDT wireless switches exist?
    I have a control issue I need some help with. I want to replace an existing 110V 15A DPDT switch with a wireless switch so that I have remote control. Can't find anything. Is my only option to use a wireless SPST switch to trigger a relay that is wired so as to simulate the DPDT switch? Wireless SPST switches are readily available.
    Feb 2001
    Redwood City, CA USA
    5,099
    198
    1009
    Thinking out loud, could you use two Wemo switches combined with the IFTTT app (if this then that) to make one the master and the other the slave and tell IFTTT to switch the slave to whatever is the opposite of the master.
    Aug 2010
    Tucson, AZ
    251
    8
    64
    Would help to know more about the application, or what you are trying to do. There are wireless DPDT using dual relays, example below states it can operate 30A.KT-G3-A USA 4G GSM AUTO Relay Switch 12V Solenoid Remote Control Box Wireless Gate Opener 2CH Output HOG Trap System 30A Relay Contact, you can get a WiFi chip. Probably other variants, including hand remotes.
    https://www.amazon.com/Solenoid-Cont...B07Q7PKW5Z/ref
    https://www.amazon.com/Solidremote-1...8UM/ref=sr_1_6
    https://www.amazon.com/Wireless-Mone...Y2/ref=sr_1_22
    Sep 2002
    Salinas, CA USA
    4,125
    259
    226
    Quote Originally Posted by rklopp View Post
    I am not aware of any wemo switches that are spdt... You are right that a pair of spst switches plus IFTTT could emulate a spdt switch, but then it would take four spst switches to emulate a dpdt switch, and you would have to solve some initialization problems and timing problems. OTOH, a single WEMO switch along with a Deltrol 8030 DPDT relay gets me the behavior I want. I was just hoping to find a solution in a single package.
    Sep 2002
    Salinas, CA USA
    4,125
    259
    226
    Mksj, interesting devices you linked. The first one might do it, but it requires a SIMM card and communicates over 4G. Thanks.
    Aug 2010
    Tucson, AZ
    251
    8
    64
    There are also numerous relay version listed on eBay that are WiFi, Alexa, smart home, etc. Do a search "Relay Wireless wifi" or use whatever wireless connection you are looking for. There are also a lot less expensive GSM models.
    5V ESP8266 ESP-01 2-Channel WiFi Relay Module Relay Module For IOT Smart Home | eBay
    Sep 2002
    Salinas, CA USA
    4,125
    259
    226
    Quote Originally Posted by mksj View Post
    Well, I should give some more info. about the application. The DPDT switch needs to handle 15A. I really don't need any additional functionality, just a simple DPDT wireless switch or relay.
    Dec 2013
    Vermont, USA
    458
    6
    113
    Google "dust collector wireless switch" and you will find various products for 120VAC which will probably be SPDT and for 240VAC which will be DPDT
