alcro1998
Cast Iron
- Nov 10, 2020
- Central Ohio
Hi, I am in the process of wiring up my HLV-H and it is a 460v machine. I have opted for the set up transformer since it was the cheapest and easiest route. The transformer will be hard wired to the machine and I will run the machine off my rotary phase converter.
I am having a bit of trouble understanding how I am supposed to wire the transformer properly and I have not been able to find an explanation on the internet.
For the input, I have wired my three phases to X1, X2 and X3 and have also attached the #3 wire since it is a 220v input. I believe this is correct.
I however am not sure on how to wire the three outputs. At the moment I have connected the three output wire to H1, H2 and H3 but I am not sure what to do with the H0 wire if it is even needed or what else I need to do. I also am not sure what I means by Line-Line for 460V and Line-Neutral for 266v.
Any help is appreciated and I hope I was able to explain this well enough. I have attached a picture of the transformer tag.
-Chris
-Chris
