Hey guys, new member here so go easy on me. I do sheet metal and welding fabrication for automotive applications and have just decided to expand into some machining, so will probably be posting here often.
Just picked up an ACRA vertical mill made in the late 80's. My space has 3 phase power according to the breaker box, but doesn't yet have the appropriate wiring/plugs ran to the space where it's needed.
The shop I bought it from had it hardwired in. I'd prefer to have it on a plug so I can move things around if needed. They had it temporarily wired just so I could verify everything worked when I got there and I snapped a picture of the wiring before it was disconnected to load up in my truck.
They had 5 wires going to it. Two (white and black) were the 110 that went to the power feeds, DRO, etc. and three blue wires were the 3 phase for the motor. After some googling I found that having just 3 wires for the motor means it's wired Delta, but frankly, building electrical is just about greek to me, so I get lost pretty fast here.
I'm going to have an electrician come in to run conduit over to a box on the wall where I'd like to have the machine. I know the electrician is going to be able to tackle the building side of things just fine, but I dont' expect him to know exactly how this particular machine needs to be wired up, so on the machine side I want to be sure I know what needs to be done. Here's what I'd LIKE to do, but I don't know if it can be done this way or if it's the 'right' way to do it... so hoping you guys can give me some guidance on whether I have this right. (or how wrong I have it!)
I would like to wire a few feet of flexible cable (10 gauge, 4 wire) coming out of this box on the mill to a NEMA L15-30 connector to match an L15-30 plug on the wall. Can I run everything - both the 3 phase and the 110 power source for the mill through a single 4 prong L15-30 connector? That would certainly make things easy instead of having two separate cables coming off the machine that have to plug into separate wall sockets.
The L15-30 connector has X, Y, Z, and G prongs. XYZ are the 3 phase power, and if I understand correctly then two of those are 110 and one is 220, so can I run the 110 stuff on the machine through either one of those 110 sides? G is ground, and it seems awfully strange to me that there is no ground for the motor, but as there is no fourth ground wire for the motor, can I just run the 110 item's ground on this pin?
