Wiring Baldor motor
Likes Likes:  0
Results 1 to 4 of 4
    Jan 2003
    Phoenix, AZ
    2,091
    10
    89
    Post
    I just got a 2HP Baldor motor 220, 1 phase. There are eight wires in the box, and a wiring diagram on the box, easy enough as all of the wires are numbered, 3-4 6-7 etc for 220, CCW rotation. Problem ...one wire is supposed to go to "J". I'm guessing this is chassis ground but I wanted to check with someone here first before I put power to it.
    Dec 2003
    Washington
    4,636
    2139
    3923
    Post
    usually Baldor motors have a thermostat with two brown leads that are labeled J. This is a normally closed click switch that opens when the motor exceeds normal operating temperature.
    If you have the part# for the motor, you can download the connection diagram from www.baldor.com
    Jan 2003
    Phoenix, AZ
    2,091
    10
    89
    Post
    Ah, that makes sense. I must not have that thermostat. I have no brown leads labled J.
    Figure I should just cap that lead?
    Is that an extra item on some motors?
    Jul 2012
    Montreal QC
    16
    Default This might help, back plate from my Baldor 2 Hp (220v single phase motor)
    220v-2hp-motordeckel-fp2.jpg[QUOTE=D. Rey;347106]Ah, that makes sense. I must not have that thermostat. I have no brown leads labled J.
    Is that an extra item on some motors?[/QUOTE
