Hello all,
I just acquired a Feeler S600B drill press. It has a 3-phase 2-speed motor. It currently only operates in low speed range. I have opened the panel to discover 3 wires connected to the switch, and 3 wires dangling inside disconnected. Also, I believe the switch at was replaced because it can only operate as on/off. Later I would like to install a switch with lo/off/hi capability.
I have very limited electrical experience, and have learned on Google to check the windings by measuring OHM's across any 2 out of 3 legs in any combination. I measured 5.3 OHM's across the known good set of wires and across the unknown disconnected wires. So I think both windings on the motor are good.
I would like the re-wire the switch to operate the high speed only, but am not sure how to do it. By looking at the motor plate, it looks like I am currently in 8P configuration. If I want to get to the 4p configuration, do I need to disconnect the 3 known good set of wires and connect them to each other, then connect the unknown disconnected wires to the switch?
After I confirm the operation of high speed, what is a switch with lo/off/hi capability called?
Thank you for your input,
-Dave
-Dave
