Hi all,
I'm bringing an old woodworking machine to Australia that I owned and used in USA (prior to moving down under). The unit is a Woodmaster 725 which originally had a 7.5 HP, 1750 rpm, single phase 60 hz, 220v motor (which will not work in Oz at 50hz).
I will be using this unit at a residential property that has a 50amp 220V single phase power supply available.
I'm interested in running a single phase to three phase VFD and as large a 3 phase motor as possible given the input power supply I have (ideally 5.5kw / 7.5 Hp) but i'm flexible.
The machine uses a simple belt drive from the motor to the cutter-head so I will be able to fit most motors into the unit and can gear it to suit my desired cutter-head speed using either a 1400 or 2800 rpm motor and appropriate pulleys.
However, i'm having a hard time putting together all the numbers including weather or not I may need a voltage converter to jump 220v to 415v prior to bringing that into the VFD. Additionally, what ratings i'll need from the VFD to run the motor I end up selecting.
Perhaps i'm making this all too complicated and I should stick with as large a single phase motor as I can get (i know Leeson makes a 50hz 5hp single phase unit) but the idea of running 3 phase and having the comfort of a "soft start" power up is very attractive and is my first choice if I can make it work.
Can anyone help me sort out what might be the best option for this type of application?
Many thanks in advance!
