#3 Sq head M2200 hyd pump crazy loud deassembled all looked good inside
Results 1 to 5 of 5
    Nov 2002
    Western ,Oh ,usa
    514
    273
    30
    Default #3 Sq head M2200 hyd pump crazy loud deassembled all looked good inside
    Hydraulic pump is really really loud on my #3 square head M2200. We took it all apart and everything looked OK inside.....
    put back together sounds as bad as ever
    Any ideas ?
    David Lawrence
    Jan 2008
    New Hampshire
    285
    140
    80
    A worn shaft seal or suction leak (between pump and reservoir) can allow air to be sucked in (air entrainment) or a clogged suction strainer could be starving the pump (cavitation)
  3. Likes lalatheman liked this post
    Jan 2008
    New Hampshire
    285
    140
    80
    If you have a suspect area of suction leak try to smear a glob over the area (shaft seal or tubing/hose) and see if the sound changes, it may help to locate a suction leak
  5. Likes lalatheman liked this post
  6. #4
    Nov 2002
    Western ,Oh ,usa
    514
    273
    30
    MMmmmmm suction leak ....why didn't I think to check for that?
  7. #5
    Jan 2008
    New Hampshire
    285
    140
    80
    Quote Originally Posted by e-fishin-c View Post
    If you have a suspect area of suction leak try to smear a glob of clean grease over the area (shaft seal or tubing/hose) and see if the sound changes, it may help to locate a suction leak
    (sorry didn’t proofread my post earlier)
