03-29-2020, 05:18 AM #1
#3 Sq head M2200 hyd pump crazy loud deassembled all looked good inside
Hydraulic pump is really really loud on my #3 square head M2200. We took it all apart and everything looked OK inside.....
put back together sounds as bad as ever
Any ideas ?
David LawrenceLast edited by lalatheman; 03-29-2020 at 10:06 AM.
03-29-2020, 04:15 PM #2
A worn shaft seal or suction leak (between pump and reservoir) can allow air to be sucked in (air entrainment) or a clogged suction strainer could be starving the pump (cavitation)
lalatheman liked this post
03-29-2020, 04:18 PM #3
If you have a suspect area of suction leak try to smear a glob over the area (shaft seal or tubing/hose) and see if the sound changes, it may help to locate a suction leak
03-30-2020, 08:04 AM #4
MMmmmmm suction leak ....why didn't I think to check for that?
03-30-2020, 07:24 PM #5
