brass nut for w&s cross slide. need help soon!
Likes Likes:  0
Results 1 to 5 of 5
    Aug 2014
    pennsylvania usa
    59
    5
    Default brass nut for w&s cross slide. need help soon!
    the brass nut for the cross slide of my machine went out Friday and from what i can tell you cant buy one. it appears to be a 1.250 by 3tpi acme thread. iv got piece of aluminum bronze to make the new nut but have no experience on cutting this style of internal thread. if anyone can give me some advice on cutting this type of thread into bronze or any info you have towards making this the help will be greatly appreciated! i need to have the part done on Monday so i need to learn on the fly.
    Feb 2004
    Traverse City, MI
    3,325
    95
    135
    Your cross slide nut was bronze not brass. It would be best if you have a cobalt HSS bit to grind the acme thread profile because the aluminum bronze will dull plane HSS fast. Grind you bit with no top relief. You could cut a normal v thread first to make cutting the acme thread easier.
    Jul 2005
    Cottage Grove, MN 55016
    7,583
    4087
    4532
    For everyone's benefit you can buy pre-made acme screws and nuts from Green Bay Manufacturing
    I don't see 3 TPI, but I bet they can make a special order. When I used to make my own nuts, I would use the cross-slide screw as a templet to grind my bit near the end that didn't have wear. Many times we would cut the thread thinner so it was the same pitch all the way and then cut the nut with a tool ground to that width. Rich
    Oct 2005
    14,348
    Gahr didn't have one ?
    So it's now past the deadline (that you posted) so how did you nake out ?
    Nov 2005
    Maryland
    8,201
    746
    1103
    I believe McMaster-Carr can have custom acme taps fabricated to your specs.
    Their tap listing includes the footnote:
    Other Sizes for Right-Hand Threads—Please specify thread size, tap depth, and material being tapped. 25345A98
    Other Sizes for Left-Hand Threads—Please specify thread size, tap depth, and material being tapped. 25345A107
    - Leigh
