I have a Bronze part for machining with the OD 172mm, ID is 165mm and length is 17mm. My machine has minimum chuck pressure as 10 Bar. i plan to use an enveloping jaws concept for holding the part, will it hold the component without chrushing i'm not sure. I've never worked with bronze, will it take the standard coolant or any special stuff. The rings are cast, donno what grade.
Thanks in advance.
Pali
Thanks in advance.
Pali
