Calibrated Dial for cross-slide on a W&S 4A???
Results 1 to 9 of 9
    Feb 2013
    Buffalo NY
    7
    Default Calibrated Dial for cross-slide on a W&S 4A???
    We bought a Warner & Swasey #4A Model M-3550
    There wasn't a calibrated cross-slide dial. There are no markings on it. We had a retired W&S #3A and thought that would work once we bored out the ID on it so it would fit on the shaft. BUT it wasn't making correct cuts. If you tried to make a .010 cut it would take almost .020. So that didn't work.
    I found a dial for the machine which has a 3 threads per inch worm screw in it. This dial is $630!!! So after a little more calling around I spoke with a gentleman who said that the machine I have is SUPPOSED to have a (4) thread per inch worm screw.
    I was wondering if anyone could verify what EXACTLY thread per inch screw our machine is SUPPOSED to have. And also, how difficult would it be to swap out the screw if we needed to.
    Thanks a bunch!
    May 2011
    4,355
    599
    1795
    So you wouldnt happen to know a machinist would you?
    Ought to be able to calibrate/mark the dial you have.
    If you think 600 is bad what would you charge?
  3. Likes Putch, digger doug liked this post
    Jul 2004
    Houston, TX USA
    29,303
    It isn't necessary to ask such questions. Get a mag base DTI (with at least 1/2" travel), clamp it somewhere so it bears, with needle at zero, against cross slide. Turn your screw one turn after allowing for back lash. Your answer will be there on the DTI in thousandths of an inch
    See - you can do your own VERIFYING
    Quote Originally Posted by saidnamedPOG View Post
    Thanks a bunch!
  5. Likes digger doug liked this post
  6. #4
    Feb 2013
    Buffalo NY
    7
    Quote Originally Posted by johnoder View Post
    yes that is probably what we are going to do. Just kind of amazing that we bought this machine without a working dial.
  7. #5
    Feb 2013
    Buffalo NY
    7
    Here's a picture for anyone that cares!
  8. Likes lathefan liked this post
  9. #6
    Jan 2010
    Indianapolis, Indiana, USA
    5,473
    2426
    930
    Since you already have a dial that fits, needing graduations, and I suspect that lathe is sitting in a well-equipped machine shop...
    neme-s.org/images/PDF_Files/Making_Graduated_Collars1.pdf
    The dial may have been changed out between payment and being loaded for delivery.
    Did W&S make any metric versions? That might have something to do with the blank dial.
  10. Likes digger doug liked this post
  11. #7
    May 2002
    South Central PA
    13,411
    2157
    3338
    Maybe there was more than one leadscrew for those machines? My old #3 is 3 TPI.
  12. Likes saidnamedPOG, digger doug liked this post
  13. #8
    Nov 2011
    Butler, PA
    894
    871
    264
    Quote Originally Posted by Heavey Metal View Post
    Walk him/us through it, why don't ya?! I guess I could go read a book and figure it out but sometimes it works better if the figuring is explained to you
  14. #9
    Apr 2014
    Alexandria, Ne.
    Yes they made metric versions alright ran a few in Houston Tx that were brought back to the states from overseas. They usually had brass name plates or plates in a foreign language though, like fast or slow being Snell or Lansome a German version. It is a pain in the --- to use these the crossslide is all out of wack. You would have to replace screw and the brass nut internally and the dial. Pretty expensive deal on a 4A. Joe Forte could probably help you, he is in Houston. D&D machine.
