How to remove the rollers from a M-1374 box tool ?
Results 1 to 6 of 6
    Nov 2002
    Western ,Oh ,usa
    489
    214
    25
    Default How to remove the rollers from a M-1374 box tool ?
    I got some new rollers for this M-1374 box tool , old rollers are locked up completely .....The shank is a press fit and there really isnt a good way to support the frame for heavy duty pressing..... thought of applying oxy-proane torch heat.....didnt seen like it should be necessary....then begain to consider cutting torch the outer race off and by letting the needles fall out there would be room for real support for serious pressing?
    Incidently... I get .564 shaft dia with dial calipers outer race OD is 1.500
    Dave
    Mar 2011
    Geneva Illinois USA
    5,888
    2436
    2278
    Did you take the roller assembly off the tool and look for a set screw holding shank to the frame?
    Tom
    Nov 2002
    Western ,Oh ,usa
    489
    214
    25
    Yeah I have the piece off that actually holds the roller ..cleaned and polished and cant find a setscrew....just now think I have figured out how to post a picture ,,,,will try now.
    Mar 2011
    Geneva Illinois USA
    5,888
    2436
    2278
    Perhaps tapered pin is used. Looks like in the picture above that may be pins holding both the roller shaft and the other shaft to the flat piece.
    Tom
    Nov 2002
    Western ,Oh ,usa
    489
    214
    25
    Finally figured how to get another picture up
    Nov 2002
    Western ,Oh ,usa
    489
    214
    25
    Well I did use the cutting torch and in retrospect I think its the way to go. By torching off the rollers it allows proper support tor the pressing opreration...and they were tight. As i see it now the only other option would be heating the carrier to expand it where it grips the shaft, it probably could be tapped out if some heat was applied.... Anyhow I am ready for action now.
  7. Likes TurningHead liked this post
