Warner & Swasey #3 M-1200 List of Oil, Grease and LUBRICANT's to use.
Results 1 to 2 of 2
    Apr 2017
    Arkansas
    45
    9
    Post Warner & Swasey #3 M-1200 List of Oil, Grease and LUBRICANT's to use.
    Headstock oil is MOBIL DTE MEDIUM,
    (ISO VG 46 MINERAL BASED R&O OILS)
    MOBIL DTE MEDIUM
    MOBIL DTE MEDIUM | 5 GALLON PAIL
    Mobil / 101057
    $86.94
    (Other - ISO VG 46 MINERAL BASED R&O OILS)
    CHEVRON REGAL R&O ISO 46
    CHEVRON REGAL R&O ISO 46 | 5 GALLON PAIL
    Chevron / 273210448
    $69.90
    76 MULTIPURPOSE R&O OIL 46
    PHILLIPS 66 MULTIPURPOSE R&O OIL 46 | 5 GALLON PAIL
    Phillips 66 Lubricants / 1074242
    $62.95
    SUNOCO SUNVIS 946 TURBINE OIL
    SUNOCO SUNVIS 946 TURBINE OIL | 5 GALLON PAIL
    Sunoco Lubricants / 437305
    $39.22
    COASTAL R&O HYDRAULIC OIL
    COASTAL R&O HYDRAULIC OIL | 5 GALLON PAIL
    Coastal / 46009
    $32.36
    International Standards Organization Viscosity Grade 46 Mineral Based Rust and Oxidation Resistant, Bearing Lubricant
    Way oil is mobil vactra #2
    (ISO VG 68 | SLIDE WAY LUBRICANT)
    MOBIL VACTRA OIL NO. 2 | 5 GALLON PAIL
    Mobil / 105480
    $88.45
    (other - ISO VG 68 | SLIDE WAY LUBRICANT)
    CITGO SLIDERITE 68 CROSS REFERENCE Citgo Sliderite 68 Cross Reference
    CHEVRON WAY OIL VISTAC ISO 68 | 5 GALLON PAIL
    Chevron / 232511448
    $72.80
    PHILLIPS 66 MULTI-WAY OIL HD 68 | 5 GALLON PAIL
    Phillips 66 Lubricants / 1074251
    $63.20
    SUNOCO HD WAYLUBE 1180 | 5 GALLON PAIL
    Sunoco Lubricants / 675305
    $40.30
    ISO VG 68 | Slide Way Lubricant
    grease is "NLGI type 0". my book says with Moly = molybdenum disulfide.
    SCHAEFFER'S 274 MOLY E.P. SYNTHETIC PLUS GREASE NLGI #0 (1 TUBE)
    Schaeffer 274 Moly E.P. Synthetic Plus Grease NLGI #, #, #1, #2 (1 tube)
    make sure to pick the white cap, NLGI #0
    the only other place to get #0 Grease is
    NLGI Grease | Shop Now
    and only in 35 pound Pails and does not list moly in it.
    MOBILUX EP 0 | 35.2 POUND PAIL
    Mobil / 103209
    $97.95
    PHILLIPS 66 DYNALIFE L-EP GREASE, NLGI 0 | 35 POUND PAIL
    Phillips 66 Lubricants / 1073957
    $96.89
    Service Manual
    http://vintagemachinery.org/pubs/2261/3760.pdf
    Made this list to help everyone out if they have a question about what to use. Calvin B helped with the info, Mr. Calvin if anything is Wrong with this list please let me know so i can Fix it.
  2. Likes rustytool, TOM RICHARDSON liked this post
  3. #2
    Apr 2017
    Arkansas
    45
    9
    1st Headstock oil is MOBIL DTE MEDIUM, "Gen purpose Hydraulic and lubrication Oil" No. H-10.
    Schaeffer Manufacturing Co. Schaeffer Oil | Synthetic Motor Oils, Engine Oils, Diesel Fuel Additives, Industrial Lubricants Manufacturer from Tech Department 112 ISO 46
    Buy Schaeffer Oil | Schaeffer Oil Full Line Of Products For Sale Online
    MOBIL DTE MEDIUM
    Mobil / 101057
    $86.94
    Chevron / 273210448
    $69.90
    $62.95
    $39.22
    Coastal / 46009
    $32.36
    2nd Light Slideway Oil N0. H-20
    Schaeffer Manufacturing Co. Schaeffer Oil | Synthetic Motor Oils, Engine Oils, Diesel Fuel Additives, Industrial Lubricants Manufacturer from Tech Department 160 ISO 68
    Mobil / 105480
    $88.45
    Chevron / 232511448
    $72.80
    $63.20
    $40.30
    3rd is the "Adhesive pressure Grease No. H75" ( no info on this yet.)
    4th is the "Moly Grease No. H80" (no info on this yet.)
    Mobil / 103209
    $97.95
    $96.89
    Service Manual
