Warner & Swasey #3 M-1200 Turret Modification undoing what was done. Lots of Photos.
Results 1 to 3 of 3
    Apr 2017
    Arkansas
    45
    9
    Default Warner & Swasey #3 M-1200 Turret Modification undoing what was done. Lots of Photos.
    looks like this W&S #3 had some work done to it holes for Bolts and Pens put in so the gear could be mounted on the other side.
    this Turret is on the back end or rather they have turned the slide around backwards. giving it a larger space between the centers.
    you can see the old Holes for the Allen Hex bolts on the other side of the regular bolts on the right of the turret.
    below you can see the bolts and the hump that was milled down in to a dove tail.
    and below here is from under and you can see the Gear Bar. is mounted on the other side. and the arm for the turret.
    this slide was just reworked and put in backwards. ( the turret does not auto rotate like this )
    and am working on putting it back.
    Apr 2017
    Arkansas
    45
    9
    looks like they did some work to the bottom of the tail/turret slide. good thing i know where a few spare parts are.
    see below how it looks like they cut some parts off that had stopped them from putting it on backwards.
    Nov 2007
    E-burg MD USA
    638
    6
    109
    CRJarvis sir,
    Any updates ? Doesn't look vary worn just bodged.. When you un-bodged it it may be a pretty good tool.
    Stay safe
    Calvin B
  4. Likes CRJarvis liked this post
