Tom S
- Jul 21, 2006
- Oak Hill, WV
I have a SC-15 4-axis machine. The "w" axis servo motor makes an unusual noise even when the slide is not moving. This noise sounds as if the motor could be under some type of load even when there is no slide movement. This noise could be compared to a rattling/humming type of noise. This noise appears as soon as the machine ready light powers up. The other three axis motors are quiet. I turned the (3) breaker switches off on the "w" axis and turned the machine on. There was no noise naturally. I am positive the "w" axis motor is making the noise. I changed out the motor with another one off of a parts machine. The same noise was still there. The "w" axis responds to both manual and automatic slide movements in both directions. The outside case of the motor will get noticeably hot even if there is no slide movement. This happens even though there is a cooling fan forcing air thru the motor.
I would appreciate any help on this problem.
