Trboatworks
- Oct 23, 2010
- Maryland- USA
I have this cut I need to make:
Approximately 12”x30” panel to remove from installed cabinetry.
1/2” ply covered with Formica 1.5” radius corners on cut.
I have to use the cutout as a door with no banding on edges.
Any tricks to make this outside of my normal Fein multimaster on the straight runs and jig saw w/downcut blade on the corners?
This sort of cut is always a PITA- hard to keep edges square with clean radius corners.
Just man up (again) and chop the thing out?
Ply edges to be stained black- need close fitup so maybe 1/16” all around after sanded out inside and out of cut.
