Avoiding wood splitting while drilling
Results 1 to 11 of 11
    Mar 2019
    UNITED KINGDOM
    10
    14
    Default Avoiding wood splitting while drilling
    Hi,
    I'm making a jewelry box for my granddaughter and need to avoid the pine splitting when I attach the hinges.
    Should I use self drilling screws?
    Apr 2012
    New Zealand
    662
    160
    189
    Quote Originally Posted by Harrycrowther View Post
    Hi,
    No, use a twist drill slightly larger than the centre section of the screw thread.
    Beeswax on the screws too, because they will be small and delicate
    Jul 2004
    central NC
    2,561
    30
    656
    The concept you are seeking to learn about is called a "pilot hole".
    Steve
    Aug 2015
    Illinois
    1,350
    973
    577
    There are tapered bits specifically for pilot holes for wood screws.
    Jun 2012
    Michigan
    9,957
    3358
    3567
    One cant beat s small bench drill press for such work. You may find yourself doing much more work with such a machine.
  6. Likes backindaday liked this post
    Mar 2010
    pacific northwest
    953
    6
    183
    Quote Originally Posted by Illinoyance View Post
    Against conventional knowledge, I will recommend against this practice. Being a former boatbuilder, I have drilled many thousands of holes with tapered drill bits and countersink- This works fine on softwood, or big work- although I have never noticed the slightest improvement in holding power ascribed to the taper.
    The problem is that a tapered drill bit is, in essence, a cylindrical wedge, with a screw feed (the flutes). It is very easy to have the bit pull into a delicate part, or near the end of a part, and split the wood.
  8. Likes Pattnmaker, memphisjed liked this post
  9. #7
    Dec 2014
    CANADA
    British Columbia
    1,276
    361
    584
    Clamp a piece of sacrificial wood to the backside(inside?) of the box to prevent blowing out the backside of the hole.
  10. #8
    Mar 2009
    4,921
    89
    902
    Been using this set. Drill bits are tapered to five different screw sizes. Adjustable collars and plug cutters. Typical use:
    A Honduras Mohogany bookshelf with black ebony plugs.
    W.L. Fuller Inc.
  11. #9
    Jun 2003
    New York State
    761
    45
    84
    Throw away the wood screws and use sheet metal screws. Then drill a standard hole.
    Pete
  12. #10
    Jul 2006
    rochester, ny
    1,882
    377
    518
    +1 for Pete's suggestion!
    Sheet metal screws hold way better than wood screws. Just about every piece of furniture I made in the last 40 years was assembled with #12 phillips sheet metal screws, black oxidized for sexiness. Except for visible hardware, hinges and such, used slotted brass wood screws. Just looked better to my eye, especially with the slots lined up.
  13. #11
    Apr 2012
    New Zealand
    662
    160
    189
    Quote Originally Posted by crzypete View Post
    Pete
    Or just drill a hole anyway. Tapered drills have their place when dealing with 10ga and larger screws but seriously, we are talking a box hinge here- screws likely 5ga or smaller.
    One could also use a bradawl, quicker and better holding power IIRC. Very old fashioned though
