Has anyone removed the cutterhead from a 12" Foley Belsaw or a similar design?
I've taken it as far as I'm comfortable with at this point. I'm putting a little more force than I think is necessary with my gear pullers, as I grab the casting. I'm backing off at this point, in fear of damaging/cracking the castings.
It appears a collar or something needs to rotate inside the bearing's casting chamber, but I'm at a loss. Neither end wants to pull off the shaft. The shaft doesn't appear to be in that bad of shape from a rust or seized up standpoint.
Any suggestions will likely be very helpful.
