I am wiring some Martin machines (fed by a Phase Perfect 355).
The rated current on each machine according to Martin is much higher than it should be based on the Kw. A Martin rep said it was because of a European rule having to do with the onboard inverter, but couldn’t give a detailed answer.
If I can’t get an answer I will wire them for the higher current, but I am curious why there is such a discrepancy.
Frank
Frank
