Delta Rockwell 15-655 3-phase wiring
JRCustom
Jul 1, 2018
Picked up an older production machine with a 3-phase 1hp motor and the Reeves speed controller (if that makes any difference). I am looking at adding a VFD instead of replacing the motor with a single phase. I noticed the machine has an external heater circuit on it. If I go the VFD route, do I need to still include the heater in the circuit or can I bypass it an rely on the VFD for protection? Thanks in advance as 3-phase is a whole new game for me.
My experience with this is that you could hook up with contactor etc but you need to hold start button in on machine and then start VFD with its button. Don't turn on VFD then push start button on machine. Stop with vfd in order not to get error code. The $89 Amazon VFDs have served me well on 3 HP machines such as Diacro bender and Bridgeports
by pass all existing controls. wire direct from vfd to motor. You can use existing switches for low voltage control into vfd. I reused a contactor as main shutoff ahead of vfd. Only turned off after vfd is shut down. Only used it because vfd fans runs all the time it has power in.
Bill D
