Delta/Rockwell 28-380 wood/metal bandsaw
Likes Likes:  0
Results 1 to 4 of 4
    Feb 2020
    Washington
    Default Delta/Rockwell 28-380 wood/metal bandsaw
    Hi,
    I have a Rockwell 28-380 that I've completely cleaned and rebuilt with new bearings, tires, etc. But I'm missing the two 4-step pulleys. If anyone has one of these, could you measure the step sizes on the upper and lower pulleys for me?
    Jul 2004
    central NC
    2,606
    31
    682
    On eBay right now are a couple of pulleys for sale which you could buy or ballpark the sizes from the photos. Search on “Rockwell 14 band saw pulley”. You can also check with Delta tech support as they still will provide some info on their older machines. On the parts diagram I found on ereplacementparts it looks like one single step and one four step.
    Sep 2002
    Salinas, CA USA
    4,154
    266
    232
    I can check mine when i am in the shop. Do you still need the info?
    Apr 2004
    Modesto, CA USA
    7,507
    1315
    does this use regular flat bottom tires or is it the kind with a bottom rib?
    Bil lD
