Finding Shop that can cut CNC holes in MDF
Results 1 to 8 of 8
    Nov 2016
    Michigan
    26
    5
    Default Finding Shop that can cut CNC holes in MDF
    I am having a hard time finding a carpentry shop or similar that has the ability to cut rectangular slots into MDF, Obviously I expect some rounding in the corners but I need to find somewhere that can cut this to very tight tolerances.
    Does anyone have any idea of where to look or how to look for a place with these capabilities.
    I am located in Mid-Michigan
  2. Likes danberens liked this post
  3. #2
    Sep 2002
    People's Republic
    2,634
    191
    1928
    You need to first find a shop with a CNC router, that will take in other work
    Then you need to show them a drawing they can read
    IF you can tolerate a radius, show it.
    Is that metric, hell most woodshops are dealing in fractions, they might be more comfortable in inch dimensions
    Aug 2012
    Pittsburg, KS
    1,215
    109
    546
    I have a commercial cnc router am sure I could cut what you show in the pic, how deep do you want those slots, how thick is the material? What tolerance do you require?
    I am in Kansas and could ship it if needed.
    Jason
    Nov 2016
    Michigan
    26
    5
    Update, Found a local shop, I wish more places listed there capabilities or machines they run. Finding specific places for small jobs is a nightmare
    Sep 2008
    CANADA
    Nova Scotia
    277
    17
    124
    Quote Originally Posted by psandherr View Post
    Give them a print with corner rads called out and actual tolerances and you might have more luck.
    Sep 2015
    410
    18
    165
    A laser could do that and give you square corners. Most steel suppliers have lasers that are more than capable. As long as they have the time
    Jul 2004
    Houston, TX USA
    29,078
    "Tight" tolerances? Will change with moisture content
  9. Likes garyphansen, g-coder05 liked this post
  10. #8
    Sep 2010
    Vancouver Canada
    862
    618
    296
    That drawing is in millimeters yes? How thick is it? Without knowing anything else about the part, it seems small for MDF to be the best material choice. If it's say 1/4" or 1/2" thick I'd suggest laser cut Baltic birch-type plywood, those thin sections at the ends of the 90mm slots would be a lot stronger, and your corner radius will be like .003". This requires a non-metal laser cutter so you have to find the right shop but there are plenty out there.
