I have an old Boice-Crane 6" planer/joiner (apparently a Model 661-H) left me by my father who must have bought it in the 60s. It's is seriously under powered with a 3/4 HP electric motor which goes out on thermal overload if it gets pushed at all. I have a 2HP motor (correct RPMs and rotation, the same shaft diameter of 5/8") that I wish to swap in. The 3/4" motor has a 7" pulley (diecast by National Hardware Specialties, Ltd of Canada), the joiner a Congress diecast 2-1/2"-A pulley.
Some questions...please pardon my ignorance and allow for my utter cluelessness, also for my wish to do this on the cheap...I'm 74 living on SS..:
I appreciate any help or advice you can give me.
- Will the Congress 2.5" pulley on my joiner be up to being driven by a 2HP motor or:
- Do I need a cast iron pulley for the greater HP?
- Do I need a bigger pulley on the joiner with that HP, as I am to understand that there are HP transfer limitation with so small a pulley?
- If I need a bigger pulley on the joiner, then I need a bigger pulley on the motor (which I will have to replace anyway: I don't think a 7" die-cast pulley would stand up). If I go to an 8" pulley on the motor what size pulley would I need on the joiner?
- If I can use commonly available 1/2" V belts, should a switch to two belt pulleys or can I get by with a more capable belt, either "A" or "AX" type, rather than the current 4L belt?
- The current 3/4 HP motor is mounted on a swing pivot so that the weight of the motor tensions the belt. Will this work with the 2HP but heavier motor or will I need to do something else? The planer is mounted on a universal stand that is good enough but has no bottom platform for mounting the motor.
