"Does" it bother you? From a work/perfomance perspective?
I would venture that if it does, a PM 64A is probably not the ideal saw for whatever it is you are doing. These saws pack a lot in for the price, but at the expense of a certian amount of refinement. As Forrest notes, they are limber. The castings are not really that heavy, or heavily ribbed/edged, and it seems they blanchard grind the tops about as fast as they are cool enough to handle out of the molds, these days. So a certain amount of movement and settling is almost a forgone assumption. However, they do seem to have things down so that it is a pretty nice saw, given a certain amount of windage allowed in some of the components and systems.
I don't think there is much gain to having one re-ground unless it really bothers you. The tops are already fairly thin, so there is a certain amount of risk that if made thinner, it will continue to settle.
My perspective on tilt arbor variety saws ("tablesaws") has modified over the years. For _many_ years, my primary saw was a mere 12" Rockwell contractors saw. I figured the only use for a tablesaw was to rough rip & cross cut stock, so it could be further processed on other machines. Dimensioning was done with jointer, planer, and shaper. Jointery was done on a tenoner. (A tenoner will do many more joints besides tenons). Plywood jointery was done on a shaper or with routers.
Then I bought a 19-teens R.D Eaglesfield TA variety saw, and began to discover the convenience of having a saw that could be set up accurately, and fence that could be made accurately square. I actually found it convenient to do operations accurately enough on the saw that I would previously have set up the shaper to run. Long angle cuts, jamb rabbeting, long bevel rabbets on the back of window stools, etc. The miter gage was big enough and accurate enough to confidently do repetive miter cuts, and even dados. Sometimes it is faster to cut a lap, or tenon, with high confidence of repeatable accruacy, instead of moving to a tenoner set up.
Funny thing, the Eaglsfield is not a saw I would reccomend, it takes way to many cranks with a full aerobic work out to tilt the blade, and the rise and fall is nearly as bad. The table is dished probably a 1/16". But everything is solid,it stays where it is put, and the throat plate is large, solid, close, and very flat around the blade area.
I've moved on to other saws, and having a solid, truly flat faced, straight, and really square to the table fence is important, Having the saw table flat, or maybe even crowned a little around the blade area with a solid, flat throat plate is very helpful. Having a large cast iron table, say 40" square or larger, is very convenient. If the table is out of flat a 1/32 or so, but every thing else is as above and very solid, you will probably be able to do most anything sensible within good woodworking practice on it. If you make small finicky or technical pieces, optimizing the throat plate area, and the fence, is where to spend your time.
If you still want a really flat, stable, tabletop, Northfield can set you up.
http://www.northfieldwoodworking.com/tablesaws/sawroller.htm
http://www.northfieldwoodworking.com/tablesaws/tablesaws.htm
smt
