How to remove pulley from Delta 11-990
Likes Likes:  0
Results 1 to 9 of 9
    Sep 2019
    CANADA
    Alberta
    6
    Default How to remove pulley from Delta 11-990
    Hi,
    I need to remove the front pulley on a Delta 11-990 drill press. There is a 15/16" bolt holding it on the shaft, however it is flush inside the pulley. Wondering how to remove it?
    Thanks for the help!
    Feb 2014
    Minnesota
    180
    30
    43
    Use a hammer and punch. Place the punch against the side of the nut, as close to the corner as possible, and give it a whack. Or, go to harbor freight, buy a 15/16" socket, and grind it down until it fits into the pulley recess.
    Sep 2019
    CANADA
    Alberta
    6
    I do have a socket that fits, but don't know which way to turn it, or how to lock the spindle from turning without damaging it.
    Apr 2004
    Modesto, CA USA
    7,071
    1194
    Should be a standard CW thread. Grab a big allen wrench in the chuck or jam wood into the pulley to stop it from turning.
    Bill D.
    Sep 2019
    CANADA
    Alberta
    6
    Meaning CCW to remove?
    Apr 2004
    Modesto, CA USA
    7,071
    1194
    Quote Originally Posted by handyguy View Post
    Correct. Use an impact gun if you have one. I would wire brush the threads and apply penetrating oil for a few days. It is probably not on too tight. It is likely a keyed and tapered fit. There may be a keyed washer under the nut.
    Do not break or bend the pulley afterwards as you try to pull it up and off. A little heat should help break things free.
    Bill D
    Sep 2019
    CANADA
    Alberta
    6
    Thanks for the advice. Tried with a large allen wrench and breaker bar. Unfortunately, the chuck just popped of instead! Will try some penetrating oil next. But not gonna get much leverage from the chuck...20190913_151201.jpg
    Sep 2019
    CANADA
    Alberta
    6
    As it happens, i really only needed access to a couple screws under the pulley - i was able to finagle those out with a small screw driver. Never was able to remove the pulley. Even tried removing the quill, but that still leaves the pulley in with a compression fit bearing.
    Sep 2019
    CANADA
    Alberta
    6
    Locking the chuck and using a socket on the top was never going to work.
