I could use some ideals on how to chop down a trim ring.
Results 1 to 8 of 8
    Oct 2010
    Maryland- USA
    3,366
    1933
    2137
    Default I could use some ideals on how to chop down a trim ring.
    All- I am on a nice older large Swan which has badly eroded teak trim rings around the deck hatches.
    In the course of restoration the sand down cut through the lap joints in the corners exposing glue joints so the client wants a teak cap placed over to renew.
    Like this- the inner vertical band is veneer ply and cannot be touched:
    I made up a router guide to run on the vertical and mill down the trim:
    This did not work- router too heavy to keep guide in line registered against vertical, depth not held as router rocks over etc etc:
    Any ideals?
    The best I have is to redo the router fence ideal with a trim router so I can hold onto the thing.
    The fence has to be round as to run the radius of corners.
    I just need to cut down the existing ~3/8" and drop a new trim ring over (glued and screwed to boat).
    The interior cannot be touched- hatch bolts down on that plane....
    Any fast ideals short of chainsawing a deck section out and bringing into shop where I can bring real tools to bear??
    Thanks all
    Nov 2012
    Connecticut
    150
    5
    30
    Are you trying to get below deck level, or are you going to have a seam between the deck and hatch visible? My first thought is a plywood guide that would clamp over the hatch, and a coller on the router to follow the edge. I assume depth of cut is important on the outer edge and horizontal edge is less important on the inside because it will be under the hatch and won't be seen. If you are going below the deck surface the outer horizontal edge would also be critical.
  3. Likes Trboatworks, stephen thomas liked this post
    Oct 2010
    Maryland- USA
    3,366
    1933
    2137
    Ah- of course!
    Not below deck plane- just need to cap existing ring maybe 1/2" of new stock or so.
    I will have to see if I can get some means to clamp down a ply guide template but you have got it-
    "Why the hell didn't I think of that".......
    Edit- I have a bunch of heavy lead pigs- I can just weigh the crap out of the ply to hold in place.
    Only problem is if I have clearance to deck hardware to lay the ply...
    Thanks!
    Nov 2012
    Connecticut
    150
    5
    30
  6. Likes Trboatworks liked this post
  7. #5
    Nov 2007
    Hamilton, Ontario
    1,100
    801
    423
    Other suggestion is to use your current fixture but add a long base to your router base so it bridges the hatch. Looks like you will have to trim the base to exactly the right length because of what ever that white thing is your picture.
  8. Likes Trboatworks liked this post
  9. #6
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    11,036
    4126
    3859
    If the hatches are similar, or perhaps even if they are not, I would use kb's idea of top pattern, but also a 3/4" thick "plug" under it.
    IME, one would trace the "plug" to fit the opening and make it carefully. Screw another sheet of ply on top of that to make the working pattern, and use a collar to run the router around the plug and cut this top sheet to be the working pattern with your next collar and bit set up. Alternately, of course, you can make the working pattern "perfectly" first, and then rout the "plug" to it.
    Tamp it in the hole, if it is loose, have someone underneath put some shims around the edge. If too tight, well that is what rabbet planes or side planes are made for.
    One of these patterns also then becomes the pattern for the trim ring pattern. I love routers, collars, offset pins, shop made guides and a good master pattern!
    smt
  10. Likes Trboatworks liked this post
  11. #7
    Oct 2010
    Maryland- USA
    3,366
    1933
    2137
    Kudos to all- you saved my bacon and I was able to knock this out.
    Made me feel a bit dense but got me on the right track...
    Soooo.....
    I rolled with Pattnmakers plan- I had a number of various sized hatches to do and one setup allowed me to chop the fixture down as I did smaller hatches and clear deck hardware etc:
    Not for the faint of heart... but it got the job done:
    The normal excitement of routing through hidden stainless screws and the like.
    A warning- kids don't try this at home-
    The guide post has stock captive between it and the router bit- a moment of inattention and things could get hairy real fast..
    All in all worked great though- I was trying to force it otherwise to get the guide pin to work as the only register and feeling like I was going to get chipped by the router horsing it like that.
    Thanks again all..
  12. Likes stephen thomas liked this post
  13. #8
    Nov 2007
    Hamilton, Ontario
    1,100
    801
    423
    Good to hear it worked out. We used to use long baseplates a lot. A rib on the top for to stiffen it up is often useful as well.
    Hope you priced a router bit or 2 into the job I often price a router bit or sawblate into the quote on rework for those hidden screws. nails, steel dowels etc.
