Thk u!
You touched on the ‘hot button’ topics of pvc and static and bends.
It has worked for me, maybe not everyone.
For the hose, I ran a solid line down to the floor and swivel with two 90 bends to allow going from one end to the other. It works well, takes weight off hose and it is out of the way for planer. (Easy to keep out of way of jointer as is on floor)
I noted in the manual that when in storage or for use on everything minus thickness planing that the “transmission” should be left in “0” not 1st.
I assume this had to do with some wear or belt/chain stretch issue. Your experience makes sense.
I will see if I can switch 1/2 way between to prevent taking a “set”
Thank u!
