Miter slot runners...?
Results 1 to 18 of 18
    Feb 2019
    Massachusetts
    31
    8
    Default Miter slot runners...?
    What are you all using. Materials, the good the bad , pre bought ? Anyone here making adjustable ones here ?
    I made a few jigs already for my Dewalt 7491 but have not been put to a lot of use yet. I made the runners out of a mystery hard wood from slats on a bed frame. I may have to re do the jigs as I found some "out of square issues with my saw.
    I think I have it squared up as good as a job site saw can be. There was some play in the motor housing I finally spotted and fixed that.
    It was not terrible and not until I tried doing some more precise cuts did I notice,
    I bought this saw to replace my old cheap model craftsman which honestly and surprisingly was a pretty true cutting saw the plastic base deteriorated so I needed a replacement . I was going to build a 2nd shed and found this 7491 used for 1/2 price. up front it seemed ok and some of the first few projects went fine. Then I crunched the numbers and found it not worth the savings and just bought a pre made shed.
    Anyhow looking to improve my wood skills
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    11,052
    4131
    3869
    This is intended to be an industrial machinery site.
    If you post import jobsite and low quality homeowner machines, they need to be accompanied by woodworking.
    You can show how you used a cheap machine, scrap lumber, and drywall screws to facilitate a complex or significant project.
    Not chit chat about the machines themselves.
    FWIW, i slit the steel slides on most of my miter slot equipment in 3 places toward one side, and thread and install set screws to expand the slit metal. That makes it possible to custom fit, and to adjust for wear.
    smt
    Sep 2009
    Apex, NC
    1,490
    739
    For various fixtures/bases that slide in miter slots, I keep a stock of hard maple slats cut to the slot size(s); easy to make on the tablesaw, and adequately durable for non-production use. Glue and screw them to hardwood plywood/dieboard fixture bases, and lubricate with a stick of paraffin.
    Mar 2010
    pacific northwest
    1,028
    6
    206
    UHMW poly works well.
    Mar 2009
    5,164
    97
    951
    I have some set screws with nylon ball tips. Better than straight screws which just grind against the miter slot.
    Jun 2001
    11,052
    4131
    3869
    Should be no contact at all between screws and slot. All the setscrews do is expand slit part of the bar. 10-32 In from the side. Gage bars are mostly T-slots on 3 saws. Old photos on hand for the 1914 saw. 30" long original miter bar repurposed for 2-way miter sled. Same thing on SCMI & Delta miter gages, but narrower bars. Some only slit one end.
    Jun 2008
    TN
    1,565
    332
    267
    Good to see you back, Stephen.
  8. Likes Joe Rogers liked this post
  9. #8
    Jun 2001
    11,052
    4131
    3869
    Thanks, Henrya!
    smt
  10. #9
    Mar 2009
    5,164
    97
    951
    Set screws are the only choice when solid metal bars are sliding in the slot. First time I learned that was from a article/picture in Wood Smith or Fine Woodworking magazines years ago.
  11. #10
    Feb 2019
    Massachusetts
    31
    8
    Quote Originally Posted by stephen thomas View Post
    smt
    Im teying to get to a point where i can start making stuff. LAcking room I need portable equipment.
    Love to find a small compact commercial/industrial grade saw I,can fold up and out of the way.
    i will post more of what I do when the equipment is all set.
  12. #11
    Jun 2001
    11,052
    4131
    3869
    Not following - are you saying i should not slit them?
    You can't believe everything you read. Heck i wrote some short articles for FWW. It's written mostly by amateurs who are as prone to error and prejudice in their practices as the rest of us online.
    Seriously, it's ok. I would peen and file them first, second, especially for T-miter bars is slit them like i actually do, would not really consider threaded inserts in T miters. Would consider them in straight flat bars. I would probably just use nylon set screws. Or maybe regular SS pushing a short snug fitting delrin rod.
    We're glad to have you. Most of us, unless someone in our family had a serious shop, started with lightweight, low budget equipment and built from there as you intend to. It's encouraging to hear that you are not letting a lack of space inhibit the learning and production process.
    Nonetheless, the forum owner's position is that there are dozens of woodworking sites catering to cheap import equipment, best to go there and enjoy likeminded souls if that is your preference.
    My position is that a lot of good woodwork is built under less that suitable conditions with some very hinky machinery. So if you show woodwork it was used to produce & it is some step above trivial shop projects, we all benefit. Your question about miter bars was fine, could apply to anything. Leave the lightweight machinery out of the discussion; ask about it on a forum where those machines are considered mainstream.
    You've heard a lot of good choices including wood and plastics. Formulating any decisions?
    smt
  13. #12
    Mar 2009
    5,164
    97
    951
    Maybe you have not noticed that Powermatic, Rockwell, General, Delta have had solid bar miter gauge bars for more than 1/2 century.
    Never made with aluminium.
  14. #13
    Aug 2006
    Virginia
    608
    845
    349
    I have a Delta miter gauge with a solid aluminum bar...peened to tighten it to the slot...Never is a tough word to use.
    Joe
  15. Likes Scottl liked this post
  16. #14
    Mar 2009
    5,164
    97
    951
    When the t-slot washer underneath the bar is a good tight fit then it doesn't matter. Anyway, don't use those stock miter gauges. Delta has been cheapening out
    their saws for years.
  17. #15
    Jun 2001
    11,052
    4131
    3869
    Ron, I really don't know what you are trying to get at.
    The OP asked about miter bars ("Miter slot runners").
    My three saws have T-slots.
    All the miter bars are steel.
    The ones i want/need to be no-shake, I slit with a jewelers saw, and insert 10-32 setscrews from one side to expand them.
    That is a the best solution for me, even for the aftermarket bars that are not T-section, because slitting and expanding them works fine even in the T-slots of my saws; in a way that Delrin plugs or Delrin setscrews would be less viable - for the T-slots-
    You can do whatever you want. Use whatever material you want.
    smt
  18. Likes Joe Rogers liked this post
  19. #16
    Mar 2009
    5,164
    97
    951
    smt
    Trying to put more life into this section of PM.
  20. #17
    Nov 2013
    Eastern Massachusetts, USA
    4,401
    4582
    4583
    smt
    Stephen,
    It looks as if you just plunge cut with a slitting saw. My question is does it matter which side is cut, closest to blade or opposite?
    Also, with those thin slits it seems even a bottoming tap may be iffy. Any advice on preferred set screw size, type, or other hints?
    In the past I've peened and filed but I like your way better.
    Update: I just saw your above post mentioning 10-32 size.
  21. #18
    Dec 2012
    Se Ma USA
    1,537
    120
    856
    When I made cutoff sliding fixtures I used .375 x .75 CRS bar stock. Recessed 1/16 into bottom of sliding jig. Took a 1/16 x 1 piece of flat stock and through bolted it on bottom of runner. My first jig had a single maple runner. I pulled it back too far once and it was about to topple onto the floor. I caught it with my knee partway down. (had big piece of stock in my hand) Anyway, knee caught it and when it landed back on the table, it landed on the blade. Lucky for me it was heavy enough so I ended up with a nasty plunge cut through it and missed any screws. All work stopped until I made the T runners.
