Need The Help of a Pattermaker
Results 1 to 15 of 15
    May 2003
    Lambertville, MI USA
    2,730
    1248
    1274
    Default Need The Help of a Pattermaker
    Do we have any patternmakers here? I need about 3 feet of 3/16 leather fillet material. Does anybody have some they would sell me?
    Thanks!
    Todd
    Oct 2014
    Maryland
    2,672
    1937
    2012
    Quote Originally Posted by SIP6A View Post
    Thanks!
    Todd
    did you try these guys?
    FMSC - Freeman Leather Fillets
    dee
    ;-D
    May 2003
    2,730
    1248
    1274
    I can buy it from Freeman but you have to buy 100 feet. 100 feet will last me about 300 years.
    Nov 2007
    Hamilton, Ontario
    1,125
    816
    428
    I think I have some but I suspect shipping will be a fair bit as getting it across the border is a pain. If you or a relative will be up here drop by with a box of doughnuts and it is yours.
    Why do you want leather fillets? Why not just use Bondo? I think it has been over 20 years since I have used leather fillets
  5. Likes SAG 180 liked this post
    Nov 2007
    Hamilton, Ontario
    1,125
    816
    428
    Sorry I just checked I have #1,2,6,8,10,12,and 16 no #3. The only reason I have this is the pattern shop I bought this building from left it behind when they moved. They got it when they obtained all the contents of a pattern shop in a foundry that went broke.
    May 2003
    2,730
    1248
    1274
    Quote Originally Posted by Pattnmaker View Post
    Well... when I learned what I know about patternmaking 40 odd years ago that's what I was taught to use for fillets.
    Now for Bondo. can I use the bondo you get at the auto parts store, or do I need some special patternmakers Bondo?
    Nov 2007
    Hamilton, Ontario
    1,125
    816
    428
    I buy the "premium" bondo from the auto body supply shop as I find the fillets sweep nicer and it sands better but lots of shops just buy the cheapest auto body shop bondo. Scraps of banding or old hacksaw blades make nice filet tools. Kindt Collins which is now owned by Freeman did sell and probably still sells Quick Build II which is a body filler that cures much harder than regular auto body filler but we only ever used it on high volume tooling.
    There are 2 important tricks with bondo fillets. When you sweep in the fillet you will get the fillet and 2 strips of bondo either side of the tool. Leave those strips alone until they go off to the rubbery stage of curing then clean them off. If you try to clean them up while the bondo is still wet you can easily mess the fillet up. If you wait to long you will have a lot of sanding. The other trick is if you have 3 corners meeting don't try to form all three fillets at once. Slick in one, clean it up and maybe even sand it then sweep in the other corners.
    With a little practice 3/16" fillets can easily be done in one aplication. Above about 1/2" they often need a second application after the first layer cures.
  9. Likes sfriedberg, Oldwrench, SAG 180 liked this post
  10. #8
    Apr 2012
    antelope ca
    15
    15
    I can remember my dad talking about wax fillets, somewhere I have a box of tools for applying them.
  11. #9
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    11,080
    4134
    3911
    I know the tools were used primarily for wax, but I have several where i softened a ball bearing enough to drill and tap for a handle. I use that with "bondo" for fillets. I would agree about using the best stuff from the autobody supply, instead of Freemans for most things. I have & use Freemans, but it gets hard as rock and is not much fun to sand or fair. It has it uses for building tooling, but when you think soft materials like leather and wax were used for fillets in the past, just use something that sands more easily.
    smt
  12. Likes sable liked this post
  13. #10
    May 2009
    Minnesota
    155
    23
    I think I just ran out of 3/16,but will check later today.
    Bondo works good short term, but will break loose in time. (if applied to wood pattern.)
  14. #11
    May 2009
    Minnesota
    155
    23
    Okay, I have about 2 feet. If that will help,I'll send it to you.
    I have quite a bit of 1/4 if you can use a little larger size instead.
    Give me your address if you want either size.
  15. #12
    May 2010
    New York
    416
    126
    300
    I got plenty, I'll find it tomorrow and post again
  16. #13
    May 2010
    New York
    416
    126
    300
    I got about 30 feet, how much you need? PM me.
  17. #14
    Nov 2007
    Hamilton, Ontario
    1,125
    816
    428
    Quote Originally Posted by b sco View Post
    How much time? I have patterns that I made for my own products that are 10-15 years old that have made over 1000 parts on a hunter and the fillets are just fine. I also have some patterns that are used in airset sand that are around the same age and have made a couple hundred parts. I have seen lots of bondo fillets that have popped out but often in loose patterns that joints are flexing or patterns that have been stored poorly. I have also seen sand get under leather fillets and peel them off.
    Most of my fillets are cut out of the wood or Renshape these days.
  18. #15
    May 2009
    Minnesota
    155
    23
    Yes Pattnmaker, probably due to poor storage practice, in and out of unheated sheds.
    But having seen this, I won't use Bondo for fillets on production patterns unless they are pretty small, when wood movement will be minimal across fillet width.
