New making blocks to dowels and more
Likes Likes:  0
Results 1 to 6 of 6
    Feb 2008
    Los Angeles Ca
    103
    Default New making blocks to dowels and more
    I知 new to wood working , have two wood lathes I致e never used. I知 interested in making long skinny balsa lure. I知 thinking a duplicator would help. Is there sonething else diy I can do to turn blocks like 2x2x12 into nice even dowels? Then of course need to shape once a have a pattern down and tested. Thank rob
    Oct 2005
    12,910
    Block of steel with 2" dia. hole in it.
    Tapped holes on face for skiving knife looking tool.
    Sep 2009
    Apex, NC
    1,380
    668
    You can rig up a plywood box that clamps on the ways with a router on top if you want them very uniform dia. Cut the corners off the stock on the bandsaw with a vee-block into an octagon to shorten the process. A "surform" rasp works pretty good to get things at a consistent dia after most of the roughing is done also. Of course there are specialized "pattern lathes" (wood lathes with carriage), and "back knife" lathes for turning long flexible parts, but the box/router is something that'll work on about any lathe. 2x2x12 isn't particularly spindly or hard to work with. Cheers.
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    11,042
    4126
    3841
    you are on a professional machinist site. Most of us have metal working lathes we can use; even though most of us prefer to keep wood dust off the metal lathes .
    Doug's suggestion is a good one - a wood working tool called a "hollow auger"
    I have also rigged up my planer for making long skinny objects with various tapers or conic sections. IOW, pool cues.
    For other small shapes, a 3D pantograph works well. A millwork client of mine is famous in the antique (porcelain) doll world and gives seminars. She had an idea for a project for which i made her 50 sets of torsos and some other none porcelain hidden parts for dolls on a Gorton 3D pantograph. Should work fine for lures.
    All the above noted, balsa is so easy to carve, it might just be faster to do it all by hand as traditional?
    PS, something is screwed up about adding pix right now. Might try later.
    smt
    Jan 2018
    NEW ZEALAND
    52
    As mentioned, a block of steel, or even wood, with a conical hole and a knife edge clamped so its protruding into the hole slightly. Think "pencil sharpener" but the exit hole if you like, is the size of the dowels you want. There are plenty of videos about jigs on youtube.
    Jun 2008
    TN
    1,502
    295
    234
    A stop clamped on your turning tool and run along the tool rest will do it. If the rest is not longe enough, think about a way to add length to it in a safe way.
    If you have a table saw, make a jig to saw the squares into octagons, then carve and shape by hand.
    Look around the web for articles about both ideas and pay attention to safe practices. Since you are new at this, think it through carefully and pay attention to your set up.
    Here is one:
    https://m.youtube.com/watch?v=VPprpxMoxV4
    But if you have not used a lathe before learn how before you hurt yourself.
    More:
    https://m.youtube.com/watch?v=lOELuHLk98E
