Paint on filler for Baltic Birch edges
Likes Likes:  0
Results 1 to 8 of 8
    Jan 2003
    Temple, Texas
    2,372
    15
    239
    Default Paint on filler for Baltic Birch edges
    Is there a paint on filler that will work on Baltic Birch Edges? This would be for painted slab doors. Other ideas?
    Oct 2012
    Virginia
    10,264
    5843
    4631
    Quote Originally Posted by Bruce Griffing View Post
    How much patience yah got?
    Long-term proven 'ere is to cut back a high-solids urethane varnish.
    First few coats are water-thin, then cut to be progressively less-so.
    By the time one is ready for the last coat or two, the voids are full, the edges approach solid wood/urethane, and the final coat(s) are compatible with the embedded 'roots'.
    Fair-decent at damage resistance where a putty-type 'cosmetic' filler would chip and fail.
    Takes time. Lots of it.
    Not so much to apply. Its the 'curing'. Polymerization. Cross-linking. Wotever.
    Must be why I mostly use store-bought doors nowadays as well.
    Cut-downs off melamine/ other laminate MDF shelving, Oak kitchen-cabinet 'kits', or even the bucks sold for 'bi-fold' closet-door use, mostly.
    Raw-edged ply, Baltic or otherwise, is jest too much like work. And won't always stay flat anyway. Not even Baltic.
    That's a 'door' thing, I suppose. Pretty much by definition as to what doors DO, one whole side will spend its life exposed to a different environment than the other. Hence the prevalence of both sides laminated in Hong Kong's fire-and-forget kitchens.
    Bill
    May 2010
    New York
    427
    135
    309
    Lacquer based sanding sealer before the urethane will save some time.
    Nov 2007
    Hamilton, Ontario
    1,142
    824
    432
    For foundry step joint cope and drag boards we use a water based automotive primer. The stuff we use is called "Hydrobase" The lacquer based ones work as well or even slightly better but I am trying to move away from lacquer based finishes for health reasons. A former coworker's cancer was blamed on the years of lacquer use.
    2 coats of primer are a minimum 3 are often needed.
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    11,107
    4137
    3917
    For a while I was using a lot of baltic birch and sealing the edges.
    For the "custom" stuff, I rolled WEST epoxy in. That is also what I use for patterns and follow boards that will get a lot of travel over pilot bearings. Consolidating, dense, easy to sand, predictable and reliable cure time. You are painting, so it won't matter, but for brightwork, the surfaces adjacent the edges need sanded back to bare wood, or the epoxy will show compared to the varnish, though it blends in perfectly on the edge itself. With French polish, it works quite well, again, so long as the flat surfaces are sanded clean. Under brightwork, if the hardener is old and turning red, it might be best to use either the slow set (which remains clear longer) or bite the bullet and get a fresh batch of hardener. WEST once did some research and found that the aged hardener actually improves some of the strength and bonding properties, but the red tint can look bad under clear finish if the coating in not uniform.
    On patterns, one heavy coat saturated in, sanded, and then a thin top coat, also sanded.
    For furniture: one coat WEST saturated in, sanded when hard, top coat with shellac made from flakes.
    For production stuff I was making briefly: spray coat the edges with General finishes Enduro-Var as part of the regular finish schedule; but emphasize coating the edges each coat. IOW, first spray edges to near saturation, finish spraying box, hit edges again. Just to point that avoids runs. With scuff sanding between coats, the edges filled and consolidated within 2 full coats. With 3 coats, definitely. For water based finish Enduro-Var sets pretty fast.
    Here's the problem I have with Baltic Birch:
    Everything I ever made with it develops raised grain within a couple years. Very disheartening. This is with a water grain raise step, then French polish. And with the Enduro-Var which is essentially self-grain raising, sanded between every coat. Many of non-production pieces were made with birch or maple solid components, the solid wood surfaces are flat, smooth, and satin glossy. Beside them, the BB has areas of extensive crinkled raised grain finish on nearly every piece. (BTW, the edges are still fine and smooth, FWIW)
    smt
    Oct 2014
    Maryland
    2,827
    2082
    2104
    how much time do you have ?
    there are better ways to treat plywood edges than paint, and even for a painted surface there are better substrates.
    Six ways to edge plywood by Free publisher - issuu
    dee
    ;-D
    Jan 2003
    Temple, Texas
    2,372
    15
    239
    Quote Originally Posted by stephen thomas View Post
    smt
    Did the Baltic Birch grain raise even under paint?
    Jun 2001
    11,107
    4137
    3917
    I have not "painted" any, but the production stackable unit system I was trying to develop had 3 coats of General Finishes Dura-Var floor finish with color toners in it.
    A piece i made for the house got the same treatment, with no color added (clear). All the maple is bright, shiny smooth as a baby's butt. The BB panels all have extensive crinkled areas. A major installation for a client, that was grain raised before french polish, still developed raised grain a month later, as it was being installed. I sanded and polished that out as it was being installed, but have the sense (don't have time to query directly yet) that it may not be as smooth as it was when installed.
    So, no actual "paint". Will be interested to hear your experience in a year or 2. I'd love to keep using the product, but am probably going to avoid it for finish surfaces and move back to something like Appleply (maple faces).
    smt
