Precision tool case wood types
Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Mar 2007
    Milwaukee
    431
    345
    203
    Default Precision tool case wood types
    I have a nice piece of Sapele that i was considering making a few tool cases out of. The cases will be for precision ground blocks and measuring equipment.
    Perhaps it was here i read that certain woods if used in a case would promote rusting. I do plan to isolate the ground tool from the wood with felt.
    Is Sapele safe to use in a tool case? Are there any other woods to stay away from?
    Sep 2005
    Northern California
    846
    104
    I have my fathers Starrett 123 calipers and they've lived for 60 years in the factory Sapele case..... bare wood on the inside AFAIKT. No discoloration yet!
    Jul 2007
    UNITED KINGDOM
    4,885
    2634
    2382
    I believe that Sapele is safe. The one to be careful with is oak. That needs to be varnished or oiled to avoid rust on contacted steel.
  4. Likes stephen thomas liked this post
    Mar 2009
    5,239
    97
    981
    Quote Originally Posted by Mark Rand View Post
    Tannic acid.
    Mar 2010
    pacific northwest
    1,049
    6
    220
    Only one I ever made was curly Koa... back when it was cheap..
    Houses a Mit indicator, stand, and arms. no rust there, I used it for aligning shafts on boats.
  7. Likes stephen thomas liked this post
  8. #6
    Dec 2015
    Connecticut
    1,043
    26
    335
    I have an Interapid indicator that’s been in a little mahogany case for a couple decades with no issues. I made it from two small pieces of scrap deck boards, routed out like Starrett used to do. A couple short pieces of 1/8” drill rod align and keep it together
  9. #7
    Mar 2007
    Milwaukee
    431
    345
    203
    Thanks for all of the quick responses!
    I do like to use Mahogany for a lot of projects. It is tough to justify for a tool case. The piece of Sapele i found is clear and has a nice straight grain with no run off. I didn't realize Starrett used Sapele.
  10. #8
    Sep 2002
    Lawrenceville GA USA
    6,268
    846
    1370
    Waxed wood protects tools as it doesnt hold moisture against the tool. The felt can hold moisture so if you are in a humid area you may want to just go without the felt.
    Charles
  11. Likes stephen thomas, MCritchley liked this post
  12. #9
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    11,056
    4131
    3872
    This one's for Stoneaxe,
    "how many toolboxes....."
    Curly Koa floor i did minor repairs to before Christmas.
    smt
  13. Likes Joe Rogers, neilho liked this post
  14. #10
    Apr 2019
    New Jersey
    74
    7
    I try not to have direct contact between wood and the tools. Instead I make a foam insert.
    I’ve been using various types of cypress and mahogany for the cases. I suspect mitutoyo ‘made in Brazil’ cases are Spanish cedar (iirc this is a type of mahogany).
  15. #11
    Mar 2007
    Milwaukee
    431
    345
    203
    I might use a sticky back foam in place of the felt. Would the foam hold moisture as well?
    I wonder if there is a felt or foam that holds oil or that wouldn't hold moisture against a precision part.
    Perhaps a permawick type of material.
  16. #12
    Apr 2019
    New Jersey
    74
    7
    I use material that is commonly sold for use with tools. So far, so good. One of them is Kaizen foam.
  17. #13
    Virginia
    28,149
    7561
    8712
    Quote Originally Posted by MCritchley View Post
    Quote Originally Posted by BHolcombe View Post
    We tested foams and molded goods for hearing aid use for years, temp cycled, "artificial sweat".
    End of the day, making mics and reproducers in bitch-to-work-with stainless housings was all there was to it. They ALL seem to absorb something or other and/or contribute their own degradation chemicals, so contact corrosion is simply unpredictable.
    Old Skewl felt blocks, "velvet", or moleskin textile at least "breath" even their own adhesive's away.
    Hard felt "points", bare wood elsewhere is easiest to do, easiest to renew, and easiest for gripping to git stuff in and out as well. Cheap, too. JFDI.
  18. #14
    Mar 2010
    pacific northwest
    1,049
    6
    220
    I put no lining in the Koa box- just step routed it to fit the tools. No rust.
    Stephen, nice floor!.
  19. #15
    Mar 2007
    Milwaukee
    431
    345
    203
    So it’s looks like no lining is the right thing to do, good discussion.
    I took a look at a Herman Schmidt case....no lining. I have full confidence in ol Herman’s decision not to have padding in a case.
    How about some photos of some shop built cases?
  20. #16
    Nov 2019
    ALAND ISLANDS
    15
    Here’s a goofy Walnut scrap for an 18” B&S square. Pretty sure I threw a little oil on it. No rust to speak of. I’ve built 90% of all my tool storage out of a zillion kinds of left over wood. I don’t recall any real issues with any of them. FWIW.
  21. Likes 4GSR, Sachmanram liked this post
  22. #17
    Apr 2019
    New Jersey
    74
    7
    I used the original liners from the plastic case, the previous owner painted the plastic case and it looked horrendous.
  23. Likes jjinpdx liked this post
  24. #18
    Apr 2019
    New Jersey
    74
    7
    I put some stainless clasps on it also. Not sure why I felt the need to write Mitutoyo on it, that was regrettable.
    Attached another case I made for an indicator.
  25. Likes jjinpdx liked this post
  26. #19
    Feb 2020
    Connecticut
    We have always used mahogany without any lining, just direct on the wood. Tried cherry and birch in the past on a very limited basis wtihout much success.
    Pete Schmidt
  27. #20
    Jun 2001
    11,056
    4131
    3872
    Is this because the wood affects the metal, or because it is less stable than Mahogany?
    Neither sounds like ideal run of the mill wood for flat board type cases. Unless the cherry was spec'd as all QS.
    I'd think QS walnut would be good.
    Even run of the mill (true)mahogany seems less stable these days than it used to be.
    smt
